Bizhub Central Admin Software
  • computon
    • Jul 2025
    Hi
    I'm new to the world of Konica Minolta, and I need to administer 10 bizhub C25x series machines. I need to configure all the machines with the same address book entries for scanning etc..
    I'm trying to be clever and save some effort, is there some software I can install on a PC to control all the machines centrally, or I am going to have to connect to each machines web interface and program each one manually?
    Thanks for any help in advance!
  • dogsbody
    • Jun 2007
    • 289
    There is a big difference between C250/C252 and C253. However Pagescope Data Administrator should allow you to import and export addresses between different machines. It should be avaliable from the KM website to download. It is a reasonable download but weel worth it if you are prepared to spend the time getting to know the software.
    Cheers.
    The force will be with you always.
    • copytechman
      • Nov 2008
      • 945
      I second that, big download, also good idea to make sure your firmware (In the machines) is current. That can have an impact on how well pagescope works with your devices.
      Regards!
      A.
      • computon
        OK thanks for that, I'll take a look.
