di 3010 c0500 error
  • euro scott
    • 127
    di 3010 c0500 error
    customer called in with a c0500 error. upon arrival the machine is hanging in initialization screen. machine will not enter tech rep, try to reset with soft reset button and it still hangs in initialization. i removed the fuser and it looks like new. the lamps test good and the thermistors look good too. machine is very low meter. please help. thanx
  • mo0651
    • 1054
    Reseat firmware card but take another one with you. We haven't had any of this model lose the nvram, but you never can tell. Make sure there is no paper jammed anywhere in the machine.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      Did you know that if you open and close the door on the right, when the 500 code is showing, it will go to the abort mode and you can get the reset screen from there.
      • harry2007
        • 52
        co500
        try this:
        open the right door, turn on the copier,push the trouble switch, press 3 key,insert service password-END-,press trouble reset, wait until warm-up, when show "please close section indicated" close right door.
        Check also if the right door close properly the switch between power supply and fusing lamp.
        If don't work rewrite the firmware.
        http://copierservicereset.com
        • djwhoo
          • Aug 2013
          • 117
          Re: co500
          hi.. quick question... to remove the fuser on the di3010 do you have to take off the front panel to get the fuser lamp wires off? or can you pull the fuser out after you pull the two wire harnesses in the rear, then have enough slack to pull the wires in the front.. thanks
          • djwhoo
            • Aug 2013
            • 117
            Re: di 3010 c0500 error
            how do i remove the fuser.. 2 screws, 2 harnesses in the back.... front panel off? or no...?
              • 14989
              There are no harnesses on the back. They are to the right and left of fuser. Remove cover to the right of fuser, two screws. Remove cover above and left of fuser, one screw. Remove switchback assembly, four screws and two connectors. Remove fuser, two screws and four connectors.
              • JustManuals
                • Jan 2006
                • 9838
                Paul@justmanuals.com
                • djwhoo
                  • Aug 2013
                  • 117
                  Hey thanks!!! I appreciate it!!!
