We're novices, trying to fix our C500 w/ 45-03 error code. Just installed a new transfer belt & yellow developer. Do we need to clean the sensors & how do we do that? Also, if the belt needs adjusting, can someone give us a how to on that? We just went into the service mode 36/image adjustment/timing adjustment/auto color registration adj & error code still comes up. Thanks much.
Code 45-03 on C500; how to clean sensor?
New sprijng
Edmund, what do you recommend we clean the sensors with & can we buy replacement springs if the tension on ours has gone soft?Comment
I usually clean the sensors with a cotton pad with alcohol and then clean them with a dry pad. Check the sensors to see if they appear to be scratched (I've caught a couple of them like that, and it caused misreadings - had to replace them).' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
Thanks & that's exactly what we did & it seemed to work. We replaced the black corona wire & the black grid wire assy, but are getting a very slight black hue in the background. Very, very light streaks going lengthwise on a 12x18 sheet. Could that be from a scratched sensor giving a false reading?Comment
After all that replacing, did you do the usual adjustments (gama, etc)?' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
Mascan42
Ibid
