I've Konica7135, yesterday i changed drum fixing etc. than copier went error. it says "right top cover open" and stops. i cant do anything please help.......
Konica 7135 trouble
Tags: 7135, activating, door switch, ect, fuser unit, inserted, konica, ops, symptoms, tested, trouble, wrong
Right top cover? I assume you're just translating from your language to english.
Could you please change the machine language to English and tell us exactly what is the error the machine's showing?' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
seth69
Well, on the right side the machine really only has one cover, which is the ADU door (unless you have a DB, but even then the machine's cover is the top one). So I can only guess that you have something wrong with the sensor that detects the state of the right side door. Check for the sensor working on the 47 mode (try to swap it with another similar sensor), and you can also verify if the sensor's connector is well inserted and, while you're at it, check for pinched wires and, as a last resort, check also for blown ICPs on the boards.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
seth69
Before going there, check also if the door is activating the sensor correctly (could be bent or something like that). If you put a piece of paper on the sensor, does the machine stop complaining?' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
seth69
Does it have a finisher fitted? I cant remember if its the same unit but 7145 used to give this message when the finisher jam clearance guides were out of place. Failing that I would disconnect the doc feeder, finisher and the drawer base(if fitted) to see if fault is definatly in the main body.Comment
seth69
If you can actuate the switch with your hand and the machine stops showing the error, then you could have a bent actuator.
When all else fails, try to flash the firmware on the machine - I've seen corrupt firmware cause a lot of strange symptoms.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
seth69
thank u for ur support,
i found trouble and fixed it,
where ???))
the thermistor of fuser section was out of work, thats it!!!
i borrowed same model and tested all modules. when fuser unit changed error missed...Comment
