SD-501 Finisher
  • Dedotch
    • 40
    SD-501 Finisher
    I have a Ikon CPP 650 (bizhub PRO 1050). I have attached the SD-501 and plugged it into the machine and power. How do I get the machine to find it? I don't have the pass code to service mode.
    Thanks Scott
  • Dedotch
    • 40
    Now I have a C-3912 error code.
    • jeroen2005
      • 48
      Press Utility button-Counters-Stop-0-0-Stop -0-1 and your in.
      • random
        A CPP650 is the equivilent to a Konica Minolta C6500 (colour printer) and you can't plug a SD-501 into a C6500 without a RU-502\501. This an interface between the engine and the accessory as the finisher is designed for a 1050.
        Also if the SD-501 is off an 1050 it won't have firmware compatable for the CPP650 and there is a dip-sw on the back of the SD-501 control board to tell the machine that it is being attached to a CPP650 not a 1050.
        If infact this is a CPP650 and you have plugged the SD-501 directly into the engine then I would say one or the other is now damaged.
        One more thing the early versions of SD-501 aren't compatable at all with the c6500. You would need the serial number of the finisher to ascertain this.
        • langelot
          • Nov 2008
          • 85
          If you still have the SD-501
          If you still have the monstrosity (sorry, but I hate this peripheral) and are looking to get rid of it, let me know - I have a customer who wants one - no matter how much I try to dissuade him from it.
          I just love that bundle-press section, what a lovely concept - I just wish that Japanese engineer who thought of that one hanged himself with those infernal pulley wires.
          Sorry, loosing my cool here!!!
