C350
+ More Options
Posts
  • digicor
    • Jul 2008
    • 1153
    C350
    I hava c350 that is blurring the blak.. only the blak.. im looking to adjust the bk dv bias? but.. its not an option on this model, or am i not looking in the right place?
    please advise
  • dbrownlee
    • Sep 2005
    • 197
    I had one do it, had to change the LPH-Black ass'y. Pn 4036-0563-01. Good Luck.
    GO TIGERS!!
    • texchar555
      Senior Production Tech
      • Mar 2007
      • 142
      wait! before you do that remove the iu's and clean the lens. you can clean the toner off but sometimes it builds a film so clean it with your cleaner and add a very small amount of water to it.
      • dbrownlee
        • Sep 2005
        • 197
        Sorry, I had assumed that all the easy stuff had already been tried. My bad
        GO TIGERS!!
        • digicor
          • Jul 2008
          • 1153
          yes the easy stuff has been done..... now its the hard stuff ....LOL
          • OutlawTorn
            • Aug 2008
            • 189
            Yeah I would have suggested cleaning all the imaging unit lens then doing a re-calibration (has always worked for me)
            Let us know how you get on, this could be useful for future reference!
            • barratec
              • Jun 2008
              • 162
              Try to clean the optical unit and the writing LED bar under the bk IU.
              Then perform the "Gradation Adjust" procedure in tech service mode.
              If it doesn't get better try to change the bk IU.
              • fixthecopier
                ALIEN OVERLORD
                • 4714
                I encounter that on all colors. Use the cleaning wand and use alcohol. Push down real hard and scrub back and forth. Then wipe with a dry pad. It will solve your problem.
                • digicor
                  • Jul 2008
                  • 1153
                  thanks peeps i will post what the fix is
