di 470 starts to come on then shuts off
  • henrys
    i have a 470 that will start to power up , i hear the fans come on ,lift motor start up..then after about half a second it shuts off , i replaced the main power switch..no luck.....any ideas ????
  • time2fly
    • Jul 2008
    • 134
    Check the fuser area usually when a copier first starts then shuts off right away it's something in the fuser, a thermister or a thermostat. on the left side under the the main front cover there is a little cover that comes off after the screw is removed, under that cover are two push bottons one of those bottons will reset the copiers error aloowing it to bott up all the way. Good Luck
    • Rolandito
      • Aug 2007
      • 90
      Once i found some staples at board that is at botton of the main board, its a brown board, i cant remember the exactly name at this time
      • mascan42
        • Oct 2008
        • 484
        Sounds like something's shorting out. Does it happen if you turn the power on with the front cover open? That would eliminate the fuser and a couple of other things that don't turn on if the cover's open.
        • Hansoon
          • Sep 2007
          • 3376
          I remotely recall we once had an issue with the main relay Ry1.
          Hans
          • Bizhub
            • 147
            Time2Fly is correct , you will find that one of the thermistors is shorting out. Take the fuser unit out and see if the machine starts up.
            Regards
            • minimerlin
              • 851
              If I remember there was a mod to fit a cover plate at the rear of the fuser to stop the fuser heater lamp cables chaffing/shorting...maybe worth a look!
              Please do not PM me without asking first.
              • mascan42
                • Oct 2008
                • 484
                The mod was for the Di450/550. It was built into the 470.
                • minimerlin
                  • 851
                  Yep..must be getting old, brain memory not like it used to be!! It was only a mod for the 450/550.
                  • feeder_supply
                    only problems... no?
                    • Mar 2009
                    • 9
                    So when I step into the motherboard a mouse urine, turns 10 seconds the screen goes blue and then nothing else, the solution was to change motherboard... good look
