transfer paper on 6500
  • zipsys
    Has anyone successfully used transfer paper in production quantities on the 6500? If so what paper and what blend shirts are you using.
  • buster68
    • Nov 2008
    • 181
    . Transfer paper is not recommended media for the C6500.
    • random
      No chance, you will need a fuser that uses oil.
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        Take a look a Joto Papers 2 part system, it is a little bit awkward to work with but it will work with most copiers and printers. The transfer is made from the copy after it exits the copier, basically you transfer the image from the copy to the transfer paper then to your T-shirt or whatever.
        Now into Ip TV KODI Boxes
