Bizhub 500(b&W)
  • poz31
    • Aug 2006
    • 86
    Bizhub 500(b&W)
    thanxx
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    The bizhub 420/500 have an issue with the sensors that detect bottle and rotation. They get dirty with toner and throw up false codes. If when the code comes up, you open the toner door, the bottle is out of position, you most likely have a dirty sensor. The only proper way to clean them is to go through the back, removing the "A" board, the flywheel one of the motors and then removing the hopper. The sensors are still up in the machine. Open the toner door and blow air straight through, and then use some canned air and blow off or change the sensors. I have had some that I went into 3 times and cleaned before I could stop the codes.
    • mtech
      • Mar 2007
      • 307
      I have also seen improper insertion of the toner bottle break those sensors. They really are not fun to replace! It used to happen all the time on the smaller models. Minolta even made a change to the holder for one of the sensors and added a tab to the front to try and keep the toner from not being jammed in any which way.
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        Once you have done this once. Leave the back screws out, the metal plate has tabs that fit into the rearer frame those screws are over kill anyway. If you do this the next time the sensor needs cleaning, you will not have to remove the back, just remove the 4 front facing screws from the metal plate and you have easy access, total time to clean sensor the second time about 20 minutes. In fact I recommend anytime you have the back fully disassemble for any reason you remove those screws to make future servicing of the toner bottle sensor easier.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • mtech
          • Mar 2007
          • 307
          That is a really good idea!
          • JustManuals
            • Jan 2006
            • 9838
            This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
            Paul@justmanuals.com
            • 8050
              • 88
              The holder for the bottle rotation sensor could also be a old style holder which allows the sensor to come out of position easily. There is a modified holder, the part # is 50GA33161E and a seal to hold sensor clip in place 4470-4024-81. Also make sure bottle is turning correctly and smoothly with these load tests. To make the bottle turn clockwise (don't do this too long as it will overtone machine!) enter dsw 56 bit 1, for the bottle to turn counter-clockwise enter dsw 56 bit 2. Good luck!
              • Kmdurrin
                Copy/Print/Network Tech
                • Dec 2008
                • 132
                Check the SSD on this model. There are a few mods available to help correct this problem.
                Parts: Its what your copier craves!
                • vedder
                  • 131
                  hi guys, reading this thread with great intrest, im having this problem on a 420, stripped it all down, cleaned, cleaned, then cleaned the sensor again, but same fault, the bottle rotates fine, but stops in wrong position, I have read through all these threads and have placed the parts on order which will hopefully fix the issue, just wondering if anyone has any tips on fitting the parts, the holder, sensor and seal, looks as though it could be tricky, got the toner section out fine, just from there.
                  Thanks in advance.
                  • poz31
                    • Aug 2006
                    • 86
                    Just a tip
                    Ok what I ended up replacing was the sensor which controls toner rotation.
                    • vedder
                      • 131
                      Hi guys, i fit a new sensor and brcket and it worked fine, bit of a pain to fit, they don`t make these things easy do they?? anyway, appreciate the assistance.
                      cheers.
                      • tecaldryn
                        • 22
                        Re: Bizhub 500(b&W)
                        hello.
                        colleagues, I have a 2403 error on a bizhub 500. I've made several attempts to solve, I changed the toner bottle sensor, main board, the wiring is responding in the test. I noticed that when I turn on the machine with the toner cartridge out, it does not generate error 2403, you can make copies, but then it generates the error again. if I turn on the machine with the cartridge in place, it already comes with the error.
                        Would anyone can help me?
                        I'm out of the service manual.
                        aldryn@siscopy-am.com.br
                        now, thanks ....
                        • brent
                          • Nov 2008
                          • 1212
                          Re: Bizhub 500(b&W)
                          someone ought to make this a sticky on this thread. it seems like this same question is asked and answered all the time. I personally hate the 420 the 421 is better. just a thought..
                          brent
                          • Itsthepaper
                            Supervisor
                            • Dec 2007
                            • 91
                            Re: Bizhub 500(b&W)
                            Good stuff guys, just couple other things to look for. Take a good look at your toner bottle and make sure it doesn't have any burs on the ends, when customer tries to jam the bottle in the machine they could sometimes ruin the bottle. I've had it that after cleaning and testing loads I'll see the toner bottle hesitate while in rotation and the bottle was the problem, I've also seen those bottles with a severe warp; roll it on a table like a pool stick.
                            I've had good luck going in with the long thin vacuum adapter from the front door and sucking up all the spilled toner really getting in good at the cup and surrounding area. It takes 5 minutes and if it doesn't work, then rip the machine apart.
                            Love the Job Love the Work.
                            • JustManuals
                              • Jan 2006
                              • 9838
                              Re: Bizhub 500(b&W)
                              This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
