error codes
  • kwieringo
    • Jun 2025
    error codes
    konica minolta bizhub 420 error code T82 after a fax has been attempted.
    Thanks in advance
    Ken
  • ni311
    • May 2008
    • 658
    Are you sure it is an error code? From what I know, the error codes for fax are formated like this C-Bxxx
    Konica Minolta Error Codes - Explanations and Solutions
    • kwieringo
      error codes for fax
      Don't know, it was reported via email by a user and the machine is in another building.
      I went to look and the code was gone from the display, so I suspect since it was a new user, they were the error.
      Thanks,
      Ken
      • mo0651
        • 1054
        T82 is a no answer code reported by the fax. Problem with other fax no answer, not dialed correctly. Need to dial a 7 or 9 or other access code before phone number. That kind of thing.
        • xpress
          • Jun 2008
          • 63
          Im getting this 2 on a c250, The fax board works on ourmachine, but when In the it nec25c2 or whatever, it just sits after making a fax, and says waiting in the job log screen, coding out to a
          t-82 (T82 Call control Answer tone (CED/DIS) waitingtimeout after dialing at calling)
          IT was in this machine for years, going to check phone line today but wierd stuff
          • chexin51
            • Aug 2008
            • 37
            possible solution
            Although this was on a C203 the fax systems are probable similar
            Problem: at a new installation
            Fax error T82 when sending a fax long distance with a Pause and then user code
            example: 914507561748P607
            on Activity Report - Result = No Answer
            Solution: Dialing Method was "20 pps"
            it should have been "PB"
            Utility - Admin.Settings - Fax Settings - Line Parameter Settings - Dialing Method = PB
