Konica Minolta di200 c0500 Fuser Checks...
  • Executechs1315
    • Aug 2009
    • 11
    Hi I have a Minolta Di-200 with c0500 code (low fuser temp.) I checked the Heat lamp, Thermal Switch and Thermal Fuses on Fuser Assembly. I reset the code and goes back to c0500. Was just wondering if Fuser Lamp, Switch and or Thermal Fuse could still be bad when a load is applied and opens up. I watched the fuser after the reset and no Lamp at all. Any imput regarding this would be greatly appreciated, I am not a Minolta Gurru...Thanks
