Hello there, guys and girls.
I've got a Konica 7085, which is a great machine but has a problem and its solution is eluding me.
The machine can be working fine, with perfectly good copies when, all of a sudden (from one copy to the other) it will start throwing out light copies (almost white). It will then proceed that way until the operator cycles the power with a long pause in between (turning it off one day and turning it on the day after, for example).
Some details:
- Sometimes cycling the power from one day to the other wouldn't be enough - it could still be giving light copies;
- The randomness of this event is relevant even to the point that, according to the operator, when the machine was throwing out light copies and when using the duplex, sometimes the duplexed copies would be good on one side and light on the other or they could be light on both sides.
Anyone ever got one of these?
Cheers!
Some details:
Cheers!
