C253 with all P codes
+ More Options
Posts
  • lanierboy
    • 149
    Hello everyone,
    i have a c253 with P6,P7,P8,P9 warning codes and will not come to ready. Constantly says stabilizing please wait.
    I did find a cut in the laser cable so replaced this as well but the machine still reports all p codes and stays on stabilizing please wait. i have also tried system and data error clears.
    HELP!
  • popcornpuppy
    • Jul 2008
    • 29
    Try changing the transfer belt and clean the ID sensors. I know on the C451 series machine there has been some special firmware released to stop the display of P codes (due to the codes appearing for no visible reason). Might be worth checking f/w version or if some special firmware is available for the P codes.
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      popcornpuppy is probably right I had one pop a P6,p7,p8, p21 right after replacing the print heads. I assumed it had something to do with the heads, so the last thing I tried was the TX Belt, I really wish it was the first thing since it's the easiest , well live and learn.
      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
      Now into Ip TV KODI Boxes
      • emujo
        • Jun 2009
        • 3009
        Book says IDC guide out of adjustment front or rear. Try adusting (3mm +-) little at a time
        • pepper38_cnd
          • Aug 2005
          • 1075
          If it is the IDC pull out the TX belt you should see a perfect pattern on the belt, if the pattern is not there forget the sensor theres nothing for it to see.
