Toner Not Turning in Konica Minolta di 550
  • nizar642
    • Sep 2009
    • 16
    hello..
    i have a problem in my copier " konica minolta di 550 " , the copies are not clear and pale, bcz the toner not turning automatically..
    Any One Help Please ?
    Thanks All For Reading
  • mascan42
    • Oct 2008
    • 484
    Is the toner trying to turn and failing, or is it not even trying?
    • ck1
      • 485
      your Develop still good condition ? how the value of ADTC ratio ?
      toner tank spong roller ok?
      • nizar642
        • Sep 2009
        • 16
        More Details About the problem
        mascan42 reply : Thanks For Replies, The Toner Is now not even turning, but only one time it turned after i touched it with my hand. but right now it's not even turning, and the toner is light not heavy..-------------------------------------------------------------ck1 reply : The Devloper is in nice condition, i cleaned it and i filled it manually with ink.but the devloper is not turning too.. to throw the ink to the printing box..and toner tank spong roller is still ok too.
        • PaperCut
          • Sep 2008
          • 21
          Clean the toner hopper, sensor, and check the gear too, On your developer check the gear if its turning.
          • copy40
            • Sep 2009
            • 13
            had a simalar problem on a di620, my fault that i hadn't fixed the rear panel on correct and there a sensor bottom left corner, (don't know what it does machine still copies but toner bottle will not turn) that needs to be blocked, have you had the back panel off or has it been moved??/??//?
            • sacha
              thanks
              thank you all, my problem has be solved, the problem was that the developer ( poudre ) MT STARTED 502 .. was not enough ,
              • Hansoon
                • Sep 2007
                • 3387
                Hans
