KONICA code 21-06
  • copyguy5
    • Jul 2025
    KONICA code 21-06
    I am receiving the 21-06 code but cannot locate it in my resouces. Anyone familiar with this. Please assist if you can.
  • CMB
    KonicaMinolta Tech.
    • Mar 2005
    • 457
    what model?
    • mikeena
      Branch Technical Manager
      • Mar 2007
      • 220
      problem
      Solution ID
      TAUS0644878EN00 Solution Usage 0
      Description
      Service code SC21-06.
      Solution
      CAUSE: Wire cleaning abnormality.
      SOLUTION: Perform the following:
      1. Check the operation of M-10.
      2. Remove the Transfer/Sep corona and check for binding of the cleaner.
      3. Re-seat the connectors on the ADU driver board.
      others could be check to see that the charge wire cleaning assy is not in the middle or where it is not suppose to be. they tend to bind up and through this code or where the charge corona cleaning gear is it jumped over the gear and is not seeded correctly. hopefully this works for you if you turn off dpsw 3-3 and 3-4 once it is solved you will never see this code again
      • copyguy5
        THANK YOU
        Thanks for the fast reply.
        • mikeena
          • Mar 2007
          • 220
          hello
          just curious did that help
          • copyguy5
            It Did The Job
            I Have Really Never Joined Into These Treads Until The Last Few Weeks. Your Response Did The Trick For Me. Thank You For Your Efforts.
            Makes Me Want To Assist Others In Our Profession...if I Am Able.
