service code
  • krtaoufik
    • Mar 2009
    • 9
    service code
    hello
    i want to know how can i reset the service code or how can i know it and if i do a reset by connecting the two jumper the service code will be return to "00000000"
  • Desert Rat
    • May 2008
    • 1089
    Krtaoufik,
    It would help us if you would post the code you are having and the model
    of machine you are looking at. Otherwise you may get the wrong advice.
    That way we can go to the manual and give you the right info.
    DR
    • Ikoner
      • Dec 2005
      • 42
      Originally posted by krtaoufik
      hello
      Huh?
      Ikon Sucks
      • moonwalker3778
        • Jun 2008
        • 87
        u can't reset in this method but surly u can blow the things.
        • krtaoufik
          • Mar 2009
          • 9
          i m sorry
          the machine is bizhub 350
          • Desert Rat
            • May 2008
            • 1089
            krtaoufik
            Thank you for posting the model. Now what is the code you are having?
            Some codes reset after the machine is repaired and some codes need
            to be reset by the tech after the machine is repaired.
            Do you have the service manual for BH 350? Is this the color or BW 350?
            DR
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              It sounds like someone has changed the admin pass code. The new bizhubs do not use all "0's" anymore. It has been changed. I do not post pass codes on public forums but I am sure someone else will. Or look in the service manual.
              • krtaoufik
                • Mar 2009
                • 9
                the copier is Bizhub BW350 and i have the service manual but there are nothing indicating this problem
                • Desert Rat
                  • May 2008
                  • 1089
                  Krtaouik,
                  I read the manual. If you are having trouble entering the service mode,
                  the book sez, the default is 8 "0's". If someone has changed this you will
                  need to get the code from them. Or sometimes you will need the admin
                  pass word. Otherwise the book sez you will have to replace the ram.
                  You may have to contact someone locally that works for a dealer.
                  It may cost you a service call.
                  I don't think I can help you. Sorry.
                  DR
