bizhub 420 (((
  • biser
    • Jul 2025
    bizhub 420 (((
    Hi all! mashine not run and C-6101 indicated. I want replace firmware (may be this help). I have firmware on bizhub 500 but this not upload of corse. Please help me, need firmware on bizhub 420.
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    C-6101 (C6101) service code on start up - The code can be cleared by powering OFF/ON but returns. Also, the scanner unit does not initialize and the exposure lamp does not light.
    Solution
    PROBABLE CAUSES:
    1.The SDB (Scanner Drive Board) has failed.
    Note :If the scanner is moved manually to the middle of the scanner and power is applied, the scanner never moves. Please check that the scanner can manually be moved without binding, and if it does, replace the SCB (p/n 50GA-905 0). In some conditions the PRCB (Printer Control Board) can also fail. If replacement of the SDB fails to resolve the issue of C-6101, then replace the PRCB (p/n 50GA 902 0E).
    2. A loose screw (or similar item) is jammed on the front side of the optics causing the optics to bind so that it is unable to return home. Remove the screw (or similar item) binding the scanner.
    Hope this helps
    Parts: Its what your copier craves!
    • biser
      thanks! I know this. Tell me please how many dollars this prcb on you region?
