Bizhub 200 firmware
  • K7_madman
    • Sep 2009
    • 11
    Bizhub 200 firmware
    How do I find out what firmware a bizhub 200 is running? How do I get an update an apply it?
    I am having problems scanning, I looked on the forms here and seem like the next step is a firmware update.
  • OBXtech
    \tek-ˈni-shən\
    • Sep 2009
    • 37
    While in service mode, select the option titled "ROM Version." It tells you on the screen what your current firmware version is.
    Enter service mode: press, in order, "STOP" "0" "0" "STOP" "0" "1" from the meter details screen
    "I have not failed. I've just found 10,000 ways that won't work."
    -Thomas Alva Edison
    • OBXtech
      \tek-ˈni-shən\
      • Sep 2009
      • 37
      I get all firmware updates from Konica-Minolta's site. And you have to have a compact flash card writer.
      1. Write new firmware to a compact flash card
      2. Turn off machine
      3. Insert card into card slot on right side of machine (just under scanner)
      4. Turn on machine
      5. Firmware will upgrade itself
      6. When the screen says "FINISHED," turn off main power
      7. Remove card from card slot
      8. Turn on machine and check new firmware status
      That's it!
      -Thomas Alva Edison
      • K7_madman
        • Sep 2009
        • 11
        when I do that I get to a screen that looks like a password screen.
        The only button on the screen is end in the top right. I tried the 12345678 but when I hit end it goes back to the computer screen.
        • OBXtech
          \tek-ˈni-shən\
          • Sep 2009
          • 37
          All zeros. Like 8 of them or something.
          -Thomas Alva Edison
          • K7_madman
            • Sep 2009
            • 11
            OK I in to firmware this is what I have
            MSC 4040-0100-G30-80-002
            Printer 4040-0050-G00-00-000
            ADF 4344-24G1-01-00
            LCT None
            Finisher 4349-71G1-01-00
            where do I find the current version?
            I did not see the compact flash slot on the side.
            • OBXtech
              \tek-ˈni-shən\
              • Sep 2009
              • 37
              According to Kon-Min's current firmware list, you have the most current version. Maybe the firmware isn't your problem.
              -Thomas Alva Edison
              • K7_madman
                • Sep 2009
                • 11
                OK I can print and Fax ok. I installed the software for the scanner...I do not have any scanners listed in control panel/ scanners. The software says install reg key? Sorry....I inherited a network with about 10 bizhubs and still figuring them out.
                Still curious on how to update the firmware....and the compact flash slot.
                • OBXtech
                  \tek-ˈni-shən\
                  • Sep 2009
                  • 37
                  The compact flash card slot is on the right-hand side of the machine just under the scanner. It is covered by a small cover that just pops off. I'll try to find a picture to send you.
                  The copier will not show up under the scanners tab of the control panel. If you're trying to set up TWAIN scanning, then someone else will have to assist you. I've only set these machines up as network scanners and do so via an FTP utility. If you want to know how to do that, send me a private message with your phone # and I'll explain over the phone.
                  -Thomas Alva Edison
                  • K7_madman
                    • Sep 2009
                    • 11
                    OK i figured out how to scan to SMB
                    • officeboy
                      Where???
                      I get all this... and its been a great help. I just cannot find where to download the new firmware from? I must be missing it.. Any help guys?
                      I'm running 4040-0100-0G00-03-002 on the MSC.
                      • Mr Spock
                        Vulcan Inventor of Death
                        • Aug 2006
                        • 2064
                        It is on the tech site of Konicaminolta under the ssd/drivers section. If you do not have access then you will need to contact someone who does to get it for you.
