Bizhub C352 fuser lamp blown / replacement
  • Tactiveboy
    • Dec 2008
    • 16
  • xcopy
    • Mar 2009
    • 57
    The units are in one piece. The only way to do it is to send a RMA(return Autority) to konica and replace it under warrenty.
    • Kmdurrin
      Copy/Print/Network Tech
      • Dec 2008
      • 132
      xcopy is correct. These unit are known as "black box" units, and are not able to be repaired. The only option you have is a new fusing unit (p/n 9J06R70611)
      Parts: Its what your copier craves!
      • corbet.dorsey
        Steal the lamp out of the fixing unit that is being replaced, good luck
