C300
  • buttalasso
    • Jul 2025
    C300
    Hi everybody,
    I have a biggggggg problem. Yesterday a client called me and told me:"The machine make a bad noise, I turned it off". "Ok , I'll arrive in a few minutes!" thinking that was a little noise. But when I checked the machine I found a big problem. The rumours is localized in the right part of the fuser like two gear that don't work fine.
    I changed the fuser = the same
    I disconnected the duplex = the same
    I checked the gear connected to the motor = perfect
    Any ideas?
    Thanks in advance
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Some one has probably put something too heavy on the bypass (maybe dropped a book or a package of paper on it), and the bypass frame is bent away from the machine so the feed gears are not fully meshed.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • buttalasso
      Thank you pepper, I'll try to check if there is something strange in the bypass frame.
      • buttalasso
        I think that you were right; I've dismounted all the gears and mounted and the rumour go away; after some error codes the machine starts up normally...but now I've another problem: now when I make a copy the paper stops at the begin of the fuser; I've checked again the gears and the motors but I think that I've mounted something wrong...other idea? Tomorrow I would like to be the winner in this fight!
        • pepper38_cnd
          • Aug 2005
          • 1075
          Something is not connected properly, probably the reg sensor. What is the jam code?
          • buster68
            • Nov 2008
            • 181
            There is a KonicaMinolta factory modification for the fuser noise. If you don't install this mod, the noise will return.
            • mabawser
              Tech
              • Sep 2009
              • 121
              Without a shadow of a doubt it is the mod from buster above!!
              Had the fault before. Its a bit of a pain to get it out(from the rear) but more because its time consuming than hard.
              • buttalasso
                • buttalasso
                  Great Buster! I think you're right.
                  I searched the parts in Minolta Italy, but nothing.
                  I searched them in Develop Italy, the same.
                  Develop Europe, the same.
                  Minolta Europe, I'm waiting an answer from ten days.
                  Is there someone who can sell me these parts?
                  Thanks in advance
                  • buttalasso
                    Sorry for the late, but the machine was fixed by the suggestions of Buster68. Thanks to everybody
