Minolta DI551 and Minolta DI5510
  • copytechusa
    • 11
    Hi everybody,
    Someone is giving me a good deal on a few Minoltas DI551 and DI5510, but someone told me that there is an issue with a gear that it usually breaks after 5000/10000 copies.
    Where is the gear located?
    Is there a way to fix this issue?
    Did Minolta Release a modification to fix this issue?
    Any help woud be appreciated.
    Thanks in advance.
  • Si@danwood
    • Mar 2008
    • 154
    Not heard of a gear breaking at all on these models let alone after a few thousand prints(have been working on these for 18 months now)
    • Kmdurrin
      Copy/Print/Network Tech
      • Dec 2008
      • 132
      No idea. We have a bunch of these in the field, and I have yet to hear about this kind of problem. You should talk to your friend, and figure out exactly which gear he might be talking about.
      Parts: Its what your copier craves!
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        never heard of such. The only small gear I had a problem with was the tiny one on the dv box and that may fail on 1 out of 20 machines after a few hundred thousand copies.
        • mascan42
          • Oct 2008
          • 485
          The only gear I've ever had problems with on these is the one-way on the decurl roller.
          • poz31
            • Aug 2006
            • 86
            I don't know exactly which gear, but there is one on the dev unit that I had problems and I started replacing it every 5k ....until I did follow an advice to prevent overtoning....there is a huge post on this problem and couple of solutions
