bizhub c252 problems...advice?
  • copytechman
    • Nov 2008
    • 969
    #16
    Didnt make out too badly there since an imaging unit alone is worth approx $300 give or take some.. I'd make good use of it... and it'd hold up a bunch better than some $400 staples mfp device thats for sure..
    Regards!
    A.
    • hodgiepodgie
      • Jul 2008
      • 284
      #17
      mhm
      i thnk you have to replace the t belt once the code has set.i believe one can turn off life counter after you replace belt.but if you wait too longyou will have copy quality issues.anyway you will have to call tech to fix it then have him turn off life counter
      • stevelz
        • Aug 2009
        • 15
        #18
        You did get a real good deal. You could double what you put into it by just selling the consumables. Your going to need a black toner on hand because it is the most used in color copiers. They are used for shadeing and for text. If I were you I would keep it. It has a good scanner on it and you won't out grow this machine in your business.
        Best wishes
