Upper fuser lamps don't cycle off, causing overheat error. New thermistors installed, continuity to control pcb checked, control pcb tested by hytec & no trouble found. What am i missing?
Konica 7055 - desperate for help
CAUSE: Failed DCPS board. The upper fuser roller heat lamp (L2) is not shutting OFF after copier has reached warm-up.
SOLUTION: To confirm, verify L2 operation in diagnostics (power ON the copier while holding down the 4 and 7 keys). DO NOT press any output code. The fuser unit heat lamps (L2, L3 or L4) should NOT be lit. If any of the lamps are ON, replace the DCPS board (p/n 55FA84512).' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
Don't forget to give some feedback so that we (and others that might find this problem in the future) know if this solved your problem or not.
Cheers!' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
