Konica minolta c350
  • RCSDIGITAL
    Konica minolta c350
    the machine has completely blank copies. The cust replaced all the toners and then blank copies continued. Everything seems to be fine exept no image at all. Also codes p4, p5, p6
    any ideas.
    Thak you
  • OBXtech
    \tek-ˈni-shən\
    • Sep 2009
    • 37
    P5 = Black imaging unit AIDC
    P6 = Cyan imaging unit AIDC
    P4 = Doesn't appear to exist???
    Make sure the AIDC sensor windows aren't dirty. Also check for proper IU connectivity and make sure those connections are not dirty also. This could also require replacement of the affected imaging units and/or the transfer belt assembly.
    "I have not failed. I've just found 10,000 ways that won't work."
    -Thomas Alva Edison
    • mrwho
      Major Asshole!
      • 4299
      The only info I got regarding that problem, could be it, could be something else, but definitely worth looking:
      DESCRIPTION: Blank copies and prints.
      CAUSE: A failed PWB-MC board.
      SOLUTION: Replace PWB-MC (p/n 4036-7811-01).
      Mascan42
      Ibid
      • oce bill
        • Nov 2008
        • 24
        I would remove the waste toner box,If it is very Heavy the icp may have blown on the main board and the dev from these units has been dumped in the waste box,
        GG
