BH161f compatible driver for Vista 64-bit?
  • mascan42
    • Oct 2008
    • 484
    I have a customer that just bought 4 new machines, including a BH161f. The 161 is right outside the boss' office. The boss' computer runs 64-bit Vista, and the customer just discovered that the 161 has no 64-bit drivers. Needless to say, the boss is not happy. This could be a case of either make it work or take the machine back.
    So is there a compatible HP driver for 64-bit Vista?
  • rankinoffice
    • Sep 2009
    • 11
    vista 32
    you can only get 32Bit vista as far as i can see on are site
    • mascan42
      • Oct 2008
      • 484
      I saw this as well. But I'm wondering if there's a compatible HP driver that could be used instead?
      • copytechman
        • Nov 2008
        • 934
        That would depend on if your machine is GDI or PCL, if it's pcl then you may have some (limited) success with a generic hp driver... if it's gdi, well, you may have some trouble since those usually are slave machines driven by the software in the pc (the driver does the work). I had a similar issue with BHC350 with a peerless controller no less.. no vista 64 bit drivers.. had to use a BHC351 standard controller pcl driver! (Fortunately that worked very well for the customer).. Regardless, good luck and I hope yours is PCL!
        Regards!
        A.
        • mascan42
          • Oct 2008
          • 484
          The 161f comes with the PCL controller standard. I was able to make it work with the Vista 64-bit driver for the BH181.
