KONICA 7135 jams when duplexing A3 size paper
  • LY3IJ
    • Sep 2007
    • 53
    a4, a4r runs fine
    replaced M6 motor- the same
    new to this model please help
  • Albonline
    • Sep 2008
    • 1151
    is this unit on a stand? large paper travels under tray 2 when duplexed , is there any thing interfering with its path?
    • LY3IJ
      • Sep 2007
      • 53
      yep its on stand with 2 lower drawers
      first side is copied ok and then jam in both doors upper and lower
      cuold not see anything interfering with paper...
      it goes easily when i move it by hand
      • mrwho
        Major Asshole!
        • 4299
        What JAM code are you getting?
        Mascan42
        Ibid
        • pepper38_cnd
          Field Service Manager
          • Aug 2005
          • 1075
          If it has drawers it is a DB not a stand. The DB is part of the paper path when duplexing. Longer paper actually feeds under the DB then back up. At the bottom of the DB there is a metal slot for the paper to feed into. There is a mylar glued to the slot entrance, if this mylar has been damage long paper will mis-feed while shorter paper feeds fine. Check the mylar if it is damaged just peel it off and clean the glue from the guide, I have found they will run fine without this mylar.
          Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
          Now into Ip TV KODI Boxes
          • HuronMan
            • Jul 2009
            • 68
            Like mrwho said, codes? How many copies? Had probs duplexing when the paper exit actuator(26NA53170) gets worn down. Same with the reversal actuator 26NA50071.
            • LY3IJ
              • Sep 2007
              • 53
              FINALY GOT BACK TO THIS ...
              it jams every time making a3 2sided copy with code 97-2
              and making strange noise...
              a4 and a4r runs fine
              • mrwho
                Major Asshole!
                • 4299
                Something for you to check:
                DESCRIPTION: J97-2 occurs when duplexing.
                CAUSE: The actuator for PS4 (ADU PS) is binding.
                SOLUTION: Check the actuator for PS4 (p/n 26NA50070) for binding. Replace as needed.
                Mascan42
                Ibid
