Bizhub ColorForce 8050
  • copyfax20
    • Oct 2009
    • 19
    A touchscreen display panel control not respond when touch. When i send print's the copier waited between pages more time.
  • random
    This can sometimes happen when something gets stuck between the touch screen and the edge surrounding it. Get a business card or something and squeeze it between edge of the touchscreen and the plastic surround. move along all four edges to remove the debris.
    • RRodgers
      • Jun 2009
      • 1947
      completely shut the copier down (the switch inside the front door. Fire it back up and see if it works fine for a while. If it does, you need to patch the Fiery. I'm pretty sure you have a 921 on it.
      • shawn Xia
        Xerox & Kinolta
        • Oct 2009
        • 24
        does it work well at copy mode?
        MSN:matchdg@hotmail.com
        Xerox & Konica Minolta Tech
        • copyfax20
          • Oct 2009
          • 19
          Yes, in copy mode work ok, but sometimes touchscreen not respond.
          Waiting failure only as presented when i send print's
          • copyfax20
            • Oct 2009
            • 19
            I already removed and clean the panel but still does not work, takes some calibration or adjustment mode?
            • RRodgers
              • Jun 2009
              • 1947
              Did you patch the Fiery? Is the Fiery an internal one? This IS a known issue.
