Bizhub 6501 fiery problem
  • thuo
    • 155
    have a bizhub c 6501 fitted with a fiery.once the machine finishes printing one job the controller tab(option on the display becomes inactive) goes off untill the machine is restarted.
    any idea
    thanks
  • thuo
    • 155
    any idea
    thanks
    urgent
    • Albonline
      • Sep 2008
      • 1147
      which firey? if 408 ds 2-1 must be set to on
      • Setright
        FSS / SPM
        • Nov 2008
        • 247
        I would start as stated above. Otherwise:
        Switch off the controller and the printer on the mains.
        Remove and re-install the SCSI cable between them. Sometimes the connection isn't mechanically sound.
        The interface boards can also be out of sync, and require replacing, but this usually gives more random faults, yours is repeatable.
        • thuo
          • 155
          bizhub pro c6501
          have connected the faulty fiery to another machine behaves the same.memory or hard disk suspect.any reset cure for this problem
          • RRodgers
            • Jun 2009
            • 1947
            Have you looked to see if there is a firmware update for this? Or a patch for the fiery?
            • random
              what options are on the machine
