Bizhub 250/350 print mem
  • SKTeK315
    Walter
    • Jun 2009
    • 142
    Hey everybody. Got a bk 250 that prints a bit too slow for cust. Printer mem is 244 mb. With an HDD. Yes set. Need more mem ?
    On a 200 with all mem cards on print board with out HDD mem is same.
    Please advise. Thanks
  • SKTeK315
    Walter
    • Jun 2009
    • 142
    Bizhub 250/350 mem
    In addition to that question.
    Can I use a mem card that's fits perfectly & snaps in, but it's shorter in hight. From a different bizhub, say a c350 or a c450 ?
    Or do I need a different print driver ?
    • mjunkaged
      • 387
      More memory?
      I think what you have in it may be maximum!!
      Besides, the print controller for the 250/350 is slower than dirt always!!
      It won't even scan! It was made when win95 was still in use, if I recall!
      I call old 1st gen. POS, give it up, customer!! How about a nice fast HP??
      • Hansoon
        • Sep 2007
        • 3391
        I think the guy said BIZHUB, not Di-350..........
        Hans
        • TheOwl
          • Nov 2008
          • 1732
          Which driver are you using? PCL or PS?
          With the PS drivers, you can turn off a function called 'Postscript Passthrough' which makes the computers do a bit of the work for the copier. Thing is, the copier is perfectly capable of handling PS data by itself, so I turn the option off.
          Other things to check are things like your network speed on the copier, make sure it is set to 'Auto' or '100mbit Full Duplex' and if it is set to either of those, just make sure the switch / computer is letting it run at 100mbit.
          One last thing is too make sure the 'Collate' option is turned off from your application. Turning this off will ensure the job is only sent once, rather than being sent to the copier for every time you want the job printed.
          • Hansoon
            • Sep 2007
            • 3391
            This confuses me, PostScript Pass through ENABLE means the printer does the work and DISABLE means the computer does the processing? Or is it opposite?
            Hans
            • TheOwl
              • Nov 2008
              • 1732
              Opposite of what you are thinking.
              Enabled means that the computer is trying to do some of the work for the copier and Disabled means that the copier will do all the work.
