biz hub 350
  • hodgiepodgie
    • Jul 2008
    • 284
    biz hub 350
    need to get into service mode. i am having problems with the printer locking up.says 75 % MEMORY IS FULL, PRINTING. customer thnks problem with copier because print job does not print i thnk its the file is too large or lack of memory. so need to find out how much memeory in printer.once again dont thnk its a problem with copier.
  • GC-SCO
    • 26
    utility/counter/details/stop,0,0,stop,0,1. press in that order ,that should do the trick
    • mo0651
      • 1054
      You can see printer memory on config page. Utility, printer some of those buttons. you are not gonna see it in tech rep. Make sure you have the Mfp priority set to printer. Utility, user, tab six I think. Use the second button. First one is display priority. Those BW don't have a major processor thats why it prints slow on large jobs. About the only real problem with that series.
      • hodgiepodgie
        • Jul 2008
        • 284
        nope
        thats for color nec need biz hub 350 b/w
        • hodgiepodgie
          • Jul 2008
          • 284
          ok
          still not clear on the sequence to get into service mode
          • mrwho
            Major Asshole!
            • 4299
            AFAIK that's the correct sequence for the bizhub 250/350. Are you sure that doesn't work?
            Mascan42
            Ibid
            • copytechman
              • Nov 2008
              • 947
              Util/ctr, check details(might be just details), stop 0 0 stop 0 1 for those machines.. don't need to press counter after pressing util/ctr button!
              Regards!
              A.
