C253 Problem on 1st Print - Black Scattering
  • pajeroid
    • Jul 2009
    • 130
    Hello - I have a Bizhub C253 that is scattering dev all over the 1st page. We have tried changing the black IU.
    I have attached a PDF example,
    Any ideas?
  • JSC
    Gimp
    • Dec 2006
    • 618
    You havn't attached an example.......... Check out the bullitin is this what your getting?
    The gene pool could use a little chlorine.
    • Bizhub
      • 147
      It will be the board !!! I only wish my handwriting was neater now
      • rprem
        • 49
        For the first print only its comes or it continues
        after changing the iu also it comes like that ah
        machine yeild ?
        Head Lines Are Made When Dead Lines Are Met
        • minoltaed
          • Aug 2009
          • 45
          We had one doing something that sounds alot like your problem and we had to replace the image control board to fix it. Send the old board in for repair and they fixed it for us.
          • pajeroid
            • Jul 2009
            • 130
            Whoops, didn't realise i'd posted this twice! What a cock! Anyway... The solution is the PRCB board so thank-you very much JSC, Bizhub & minoltaed!
            The post I have been following is http://www.copytechnet.com/forums/ko...cattering.html This post does have an attachement. Sorry for the balls-up!
            Thanks once again!
