I looked at the PDF and to me the scattering looks like blue, but I'll assume it's black. Try running the device in test mode and print out your half tones for each color, does this scattering appear on each printout? If so, you either have a 2nd bad I/U (slight possibiltiy) or a problem with HV1 or HV2. Both HV boards are a bear to get to (HV1, the lower bd is the worst). You might want to ensure that you have good contacts for the HV contacts on both boards prior to replacing them. EMujo
