Hi guys. C350 says jam @ duplex storage or transfer unit. Checked everywhere Looked for small pieces. Blew out all sensor areas. Under over in. Checked all sensors. Nothing is hanging up. Nothing is blocked. All doors close right & lock on both sides. Gives jam ind. on power on. Help. Even unplugged for few min. Still jam. Also on power on, starts booting up then makes that jam ratchet sound & sows jam.
C350 jam
Tags: buckle, c350, cust, duplex unit, failure, jam, registration roller, snapped, sound, transfer unit
Are you getting any code when the machine complains about the jam?
Anyway, check out this:
DESCRIPTION: False exit jam is indicated; no paper jams can be found.
CAUSE: Sensor failure.
SOLUTION: If the copier is equipped with a duplex unit verify that the actuator for PC-1, in the duplex unit, is working correctly.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
If I got it correctly, the ADU only has 3 sensors - the PC1 should be the one at the bottom. But of course it wouldn't hurt to check them all.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
C350 jam
Thank you all. Duplex sensor actuator popped out probably when cust. removed a jam backwards. I looked at another c350 duplex unit & saw that it's missing the top flag. 2 screws popped dup cover off snapped actuator back in. Turned on. Done. Thank you very much for your help. You put me on the right trackComment
One thing on these boxes, I find that if you clean the registration roller often it won't jam as much either. Also, i had to adjust the paper loop (buckle) apon machine install as some of the trays would jam for no reason.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
