C351 - Where are my tray 3 and 4 ??
  • nasspro
    • Aug 2025
    Hello, I'm french and i don't speak a good english... you should be cool with me...
    I get a old bizhub c351, I've done a logical format on it.
    But now C351 don't recognise tray 3 and 4 (A3 paper format)
    How can I find those tray again?
    Should I'll do a firmware upgrade? I don't know the steps for update firmware.
    Can you help me please?
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Did the machine recognize trays 3 and 4 prior to the logical format? Also make sure that both trays are actually plugged in to the main body.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • mrwho
      Major Asshole!
      • 4299
      My first idea was to answer your question with "did you look under your copier?" but that would be too mean - even for me.
      So, here's a question: when you say the machine doesn't recognize trays 3 and 4, do you mean that you can't print to them, or you mean that you can't even select them when copying?
      Cheers!
      Mascan42
      Ibid
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        Are the trays shown on the main control panel? Or are they completely missing there? Are you trying to print to the machine and the print driver is not showing them?
        Logical format on the hard drive??? If that was the case, this should not have any effect on your configuration. Doing this will clear the hard drive of any user one-touch programming, including user box and copy track data. Nothing else is affected.
        Did you do a data clear? Is that what you meant?
        Tech rep, system 1, initialize, data clear
        When this is done, it sometimes takes the machine a few moments to do its thing, and then displays OK, with instructions to cycle the main power switch. If you did not do that properly, you will encounter some problems and need to do it again.
        You could try a trouble reset. Those trays might have been locked out due to a malfunction, such as failed control board for the PF-202 itself, or paper stuck in the lift mechanics.
        Tech rep mode, system 1, initialization, system error clear.
        After pressing the button, wait until the control panel indicates OK and then cycle the main power switch.
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
        • nasspro
          Hello,
          The trays are correctly plugged, but I can't see theme in the touch screen...
          • mrwho
            Major Asshole!
            • 4299
            That's very very odd - a formated HD shouldn't cause that. I'd look for some pinched/damaged wires (connecting the drawer base to the machine) or some blown fuse.
            An alternative could be, as you said, a firmware upgrade - it's easy, but you need to know how to, and you need to have the firmware.
            Mascan42
            Ibid
            • forbes
              I have just resolved a similar problem with a Canon copier, through this forum with the kind assistance of Mr Fixit, from the US.
              For Canon IRC copiers, the main power feed has to go into the accessory casettes, and thence by daisy chain to the main printer. This is counter intuitive. Is it possible that your power leads have become interchanged? It would be lovely if this information which I obtained here in Australia from an American helped you in France.
              Regards
              • nasspro
                Hi,
                Can you explain me how to upgrade my firmware?
                Or Where can I find a tutorial for that?
                regards
                • mrwho
                  Major Asshole!
                  • 4299
                  I can, but only later today or tomorrow (my timezone is GMT), since I'm working right now. Try to get that info from someone else - if no one else can helpo you, I will.
                  Good luck!
                  Mascan42
                  Ibid
                  • nasspro
                    Good luck!
                    hi,
                    I get this famous firmware.... How can i flash my bizhub ???
                    • forbes
                      hi,
                      Sorry, I have never done this myself, and can't asssist you.
                      • mrwho
                        Major Asshole!
                        • 4299
                        Sent you a PM with a brief description and some links. That, along with what you get on the service manual, should suffice.
                        Good luck!
                        Mascan42
                        Ibid
