C353 scanning please wait screen
    • 30418
    got a c353 scanning compact pdf 300 dpi
    machine scans in all copies but never send them, please wait screen appears and locks up machine.
    no copy no print
    have to power cycle the machine
    firmware is J8 level
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Almost sounds like a memory issue- have you swapped that out yet?
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • mascan42
      • Oct 2008
      • 485
      Are you scanning to FTP, SMB or email?
      • srvctec
        • Oct 2009
        • 827
        Another thing I should have thought of besides what mascan42 asked- what happens when you scan to the hard drive, i.e. user box?
          • 30418
          scanning
          scanning smb compact pdf mode 35 sheets 11 by 17
          please wait screen on touch screen takes over and locks machine
          memory check ok
          hhd read and write check ok
          • Stirton.M
            All things Konica Minolta
            • Oct 2009
            • 1804
            Update the firmware to R6.
            Afterwhich, I usually do a data clear operation. Backup your one touch and copy track data before you do this. Page Scope Data Admin is recommended. Print out all your network settings. Then do the firmware, and follow that up with a data clear.
            Your hard disk will be disabled, be sure to re-enable it in tech rep. If you had a fax unit installed, you will also need to re-enable that option in tech rep. Be sure to initialize the fax board in tech rep as well. Upload user data with Data Admin. Program network settings.
            If these steps do not correct the behavior, check the memory on the MFB, including hard drive. Reseat connections on these.
            "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
            ---Groucho Marx
            Please do not PM me for questions related to Konica Minolta hardware.
            I will not answer requests or questions there.
            Please ask in the KM forum for the benefit of others to see the question and give their input.
