Auto Document Feeder BizHub210
  • ravikumarj
    • Apr 2007
    • 49
    Every single original feeds in primary then get jammed.
    Any sensor or the board in ADF.
    I ve removed, cleaned the feed rollers and sensor.
    Kindly help me with solution.
    Thanks in advance.
    Ravi.
  • moonwalker3778
    • Jun 2008
    • 87
    there is a pre scanning sensor,just before the original turns in to platen glass,opposite to that sensor one Mylar sheet is there that may be worn out or deformed. hope this helps you
    • ravikumarj
      • Apr 2007
      • 49
      Document feeder Biz hub 210
      Thanks for the post, I found there is no obstruction of mylar, I ve already fed thick sheet and cleared the path.
      It takes the primary feed then it stops in the glass.
      Any sensor can be suspected?
      Ravi.
      • Rudi
        • Jun 2007
        • 251
        The hook of feeder lock lever might be broken on the rear side.
