BizHub 700 Error code C3503
  • ravikumarj
    • Apr 2007
    • 49
    Kindly let me know the section of the error and remedy
    Thanks.
  • montana
    • Aug 2008
    • 392
    hi...sobody told me it is afuser temerature error...try to reset the machine
    i hope it is help my dear....
    thanks..
    • ravikumarj
      • Apr 2007
      • 49
      call code reset
      Thanks for the post.
      Yes it is heater section Low fusing temperature..
      Normally resetting procedure in Minolta is just open the front door and close or swith OFF and ON But
      Bizhub reset procedure is little different
      We have to press utilitty mode and switch inside door switch on and off.
      then appears RESET with arrow yes.
      Which I was not aware.
