minolta DI-470 (strange problem)
  • geltrons
    • Apr 2007
    • 37
    Good day all
    i am facing a problem with Minolta Di 470 copier. It shows add toner. The hoper motor is not rotating _ removed the motor and checked, working OK_
    no error coded displayed . tried to move the hopper from home position and switch on the machine, still not moving and coming to the home position and no error codes. I have the complte service manual with me. any one had this problem before please replay
    regards
    Thomson
  • ravikumarj
    • Apr 2007
    • 49
    Add Toner
    Hi,
    I hope you have checked the add toner sensor or tryied with another toner Hopper. Then clear the waste toner container also memory reseting procedure.
    Ravi.
    • geltrons
      • Apr 2007
      • 37
      good day Ravi
      Thanks for replaying Mr.Ravi
      i havn't checked the sensor
      i will come back to you after
      checking it
      • geltrons
        • Apr 2007
        • 37
        Good day Mr. Ravi
        I was busy that is why delayed.
        FYI i am not good in minolta copiers. As per your instruction i checked the copier again . The hopper unit do not have any toner sensor except a toner botle home position sensor. On the developer unit ther is a sensor mouted outside the unit and ofcourse the atdc sensor . unfortunatly i dont have a replacement for that. manualy fead toner into toner collecting unit in the developer unit and into the developer also, but the same add toner displayed. My questan is if the toner sensor is not working the toner botle should rotate
        please advice.
        how is the memory reset done and what is the consequances
        regards
        • ravikumarj
          • Apr 2007
          • 49
          Di 470 add toner problem
          Some time ago i ve faced similar kind of problem in Minolta cs pro 3000, Customer fed the toner bottle as it is without removing the seal of the toner bottle.
          When i removed the toner bottle no seal but seal stuck in side the hopper.
          Only when i vacum and clean the roatating hopper i came to know a white substance that's the sealing sticker stuck inside.
          pl try and good luck for you.
          Ravi.
