6501vs 6500 charger
  • levino
    • Jul 2009
    • 38
    6501vs 6500 charger
    Hai,
    Any difference between KM 6500 and 6501 charger units?
    Thanks!!!!
  • Si@danwood
    • Mar 2008
    • 154
    No both use A03ur70300. However the C500 coronas work , but are approx 4 x the price!! Si
    • tech51
      • 846
      They are different. 6501 charge units are designed to use a height adjuster (to help eliminate uneven prints). I don`t know if they are compatable with each other, Ive never tried fitting a 6500 corona into a 6501 (or vice versa). If anyone has tried and results are ok please let me know so I can reduce my car stock !!!!
      Part numbers are A0UR71200 = 6501, A03UR70300 = 6500. Cheers
      • Albonline
        • Sep 2008
        • 1153
        6500 crg units in 6501 will bite you in the but! they only last a short while before causing cq and misting problems.
        • levino
          • Jul 2009
          • 38
          hai Tech51,
          I also think these two are different,because the design of the body is different
          Thanx
          • Si@danwood
            • Mar 2008
            • 154
            News to me we have been using the same(A03ur70300) with no ill effects whatsover for the last 9 months..... We cant have been that lucky surely!! Si
            • brian155
              • Jan 2008
              • 50
              I agree with Si that A03ur70300 work with both but if you have a fussy customer try using the A03ur70300 housing with C500 gold coated grids for best results on copy quality.
              • StormyKnight
                • Dec 2008
                • 50
                Thats one thing I have noticed, these coronas can have either gold or silver grids....whats the go with that?
                PS I haven't seen any issues with either though...
                • Si@danwood
                  • Mar 2008
                  • 154
                  The gold coloured grids intially were for the c500,the silver for the c5500/6500. Both are interchangable but the gold ones giving a prolonged life.However the gold units are approx 4 x the cost of the silver ones! This would be ok if they lasted 4 x longer which inevitably they do not!! So its a personal judgement/call which ones to use..Si
                  • StormyKnight
                    • Dec 2008
                    • 50
                    Hmmm, perhaps the reason is that we have some coronas left over from the 8050 & they are gold.....
                    They still seem to work OK.
