I am having a problem with toner getting backed up in the belt cleaner. We have cleaned the pipes and waste toner is making it to the toner bottle but obviously not all of the waste toner is getting taken out. Have also installed a new cleaning unit for the transfer belt.
c6500 issue
toner
Hi ya
Check the toner type as it may be wrong some people cut off the tags to make 650 into 665
Gerry -
let us know what fixed your problemSteve Baker
hachet1_12@outlook.comComment
One of two different problems here due to toner build up.
First is excessive humidity. It tends to make the toner sticky and doesn't flow properly through the spigot of the cleaner unit. If you can reduce the humidity to between 15-25%, that should be good.
The second is check your toner filter on the right side of the machine. Depending on whether you have a PF-601 or not, there will be either a plastic cover over the bottle, or a swing arm locking the unit in. Replace the filters if they are clogged."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
This was an old C500 problem as well to which the solution was a new rom for the engine. Is your firmware up to date and is the machine operating in the Q-zone regarding temperature and humidity ?Comment
Take the Toner Filter that Stirton mentioned, and remove 4 of the eight filter pieces...this will give you a better air flow in the mashine and provide toner spilling aroundIf sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
C500 toner is backing up in cleaning unit and getting hard & dumping,
if this is what is going on
konica put out special firmware up grade for this & this onlyComment
