Konica 8050 error SC81-01
  • Coptech
    worker drone
    • 460
    #16
    That is not for extra paper storage no matter how much it looks like a good polace to store paper. You are correct in that it stopped the tray lift. If you took all the paper out except for the paper that is supposed to be there, and turn the machine off and on, does it work again? Is the tray indication on the display normal or is it grayed out?
    • copyplus
      • Jul 2009
      • 100
      #17
      I tried to turn the machine on and off taking all the extra paper out. The paper tray indicdation is blinking and add paper in tray one is displaying on the screen.
      • Coptech
        worker drone
        • 460
        #18
        Usually, when there is something stopping the tray lift, the machine will disable that tray and has to be reset using a different dipswitch setting. However, they gray out the paper tray on the display when they do. If it is still blinking, it sounds to me like it popped a cable, or an ICP that drives the lift motor. I honestly think you need on-site service on this one. I could be wrong, but it sounds more serious to me. If there is no local service, call 1-800-456-6422 and they will help you find a nearby service center.
        • copyplus
          • Jul 2009
          • 100
          #19
          what is the procedure to enable the tray in the service mode?
          • copyplus
            • Jul 2009
            • 100
            #20
            If I click on the tray one indicator on the panel it greys out and stops blinking.
            • Coptech
              worker drone
              • 460
              #21
              same 25 mode but this time set switch 18-0 to off
              • scallanjoe@yahoo.com
                • 51
                #22
                Originally posted by copyplus
                The machine was running ok and turned the machine off. Few days later I turned it on and I am getting Error code SC81-01. Will someone let me know what this code means and how I can get rid of it. thanks
                hay i am unemployed 9years w / konica direct how much do they pay well trained techs
                up there in canada
                • copyplus
                  • Jul 2009
                  • 100
                  #23
                  Thank you very much. The problem is solved with 18-0. Great help
                  • Nisar235
                    • Nov 2009
                    • 13
                    #24
                    hi
                    dear its PRCB (printer control board) has been damaged. when you will replace it and you will also give the serial no of this machine to its memory and this way your problem will remove.
                    regards,
                    nisar khan
                    Pakistan
                    • copyplus
                      • Jul 2009
                      • 100
                      #25
                      HI
                      My copier colorforce 8050 prints very dark even setting up from the document printer set up mode to 85% bright. Moreover, the blue is printed purplish. Is there any set up to reduce the darkness of colors for digital printing. thanks
                      • copyplus
                        • Jul 2009
                        • 100
                        #26
                        I did not get any response from anyone yet. Would anyone let me know how to caliberate the colors. My machine colorforce 8050 is printing dark and blue is purplish.
                          • 51
                          #27
                          1st have you cleaned p / heads/m-c grid & wiress/,
                          2ed is the problem off the glass or print' if print are you useing comand work ststion,
                          3rd what dose the density out put charts look like
                          4th do you have a s/man i can just give you page #'s other wise there's a lot of typing
                          • copyplus
                            • Jul 2009
                            • 100
                            #28
                            1. Yes
                            2. both
                            3. printed a test chart. The Blue and Magenta seems ok but the yellow is greenish and black is reddish.
                            4. I dont have sm for this particular model but have some other manuals. I don't know which other machine is compatible with colorforce 8050.
                              • 51
                              #29
                              1. Yes
                              2. both
                              GOOD / HOW ARE THE TRANSFER ROLLERS INSIDE THE THANSFER BELT
                              KONICA'S c500 & (MINOLTA'S CF1500 ) I THINK IT'S CF1500
                              ANYWAY SEND ME A E/ M ADDRESS I CAN SEND YOU A 8050 BOOK
                              • copyplus
                                • Jul 2009
                                • 100
                                #30
                                aldycopy@hotmail.com
