c353 has black dashes and lines on prints
  • krm
    • Aug 2009
    • 233
    The problem is most prominent on black and white prints, but displays on color also. I tried new black I.U and new transfer belt and problem remains. Any ideas?
  • copytechman
    • Nov 2008
    • 929
    Had something like that, looked kinda like sheet music, it didnt do it on the test/demo page, but did on the grad sheets.
    Ended up being the mfp board.
    Regards!
    A.
    • krm
      • Aug 2009
      • 233
      Thank you, is a firmware upgrade necessary with this new board, or will current version work?
      • copytechman
        • Nov 2008
        • 929
        Mine had at least r5 on it b4 I changed it out. (btw the firmware update b4 flippin the board didnt change a thing), I'd flash it to latest if you dont know what version is on it if/when u get it.. but u can try it b4 flashing it regardless.. swap over all components (memory/nvram etc) after (or b4) installing it in the problem machine.
        Regards
        A.
        Btw i tested mine with a brand new board out of a new machine for reference purposes.. just the board, kept the nvram etc etc from the old on onto the new one.
        (yes, I did try everything else 1st, flippin memory/nvram etc etc)
        ohyes the c353 mfp board isnt the same as a c203/c253 bd.
        • tech51
          • 846
          I agree with Copytechman. I`ve had to change 3 mfp boards all within one month!! You get various faults, lines in colour only, lines in B/W only but the best one I had was a pale band of grey in b/w which turned into a pale band of magenta in a colour copy. The replacement boards have a different part number, so I`m assuming they have been modified.
          • copytechman
            • Nov 2008
            • 929
            That sounds expensive! Hope they were under warranty or something!
            A!
            • krm
              • Aug 2009
              • 233
              I replaced pwb-mfp and it never comes out of warm up. I figured I would load firmware, but the imaging tool is giving me fits. Everything appears to load to compact flash o.k, but when I open flash drive it asked me to format drive. I can not access files on drive. Anybody run into this, I tried 128 and 256 cards. Does the mfp board come with firmware on it?
              Thanks.
              • tech51
                • 846
                You won`t be able to read the files on the cf card from a windows PC, the card formats in a different format (VX works I believe) when the files are written to it and windows can`t read it. Assuming you`ve loaded the cf card correctly with the firmware it should be good to load onto the mfp.
                Brand new boards do not have firmware on them.
                • copytechman
                  • Nov 2008
                  • 929
                  Those machines (at least with me) only seem to like 128mb cards and it can be picky about the make/model of card @ that... Theres a thread here somewhere where we've compiled a list of known working cf cards for this model.
                  Mine had firmware preloaded since i took it out of another known working machine for testing.
                  I don't have too much trouble w/the toolkit.. browse to firmware and write to card drive letter. Thats all I do.. wait for the confirmation of checksums screen and your done.
                  Regards!
                  A.
                  • krm
                    • Aug 2009
                    • 233
                    A 256 mb card worked well. The prior cards may have been corrupted via formatting. The pwb-mfp was bad. Thank you for your help.
                    • copytechman
                      • Nov 2008
                      • 929
                      Your quite welcome...
                      Regards!
                      A.
                      • kmcopier
                        PSP
                        • Oct 2008
                        • 183
                        there is an technical information for this problem
