Resetting Konica 7045 to factory default
  • acidbag
    • Oct 2009
    • 22
    Hello...
    Does anybody here have the reset memory to factory defaults code/instruction for Konica 7045?
    Found instruction below for Konica 7020, wonder if its the same for Konica 7045.
    http://www.copytechnet.com/forums/ko...ca-7020-a.html
  • suomi
    • Oct 2008
    • 152
    • albasoul06
      How to reset the machine (initialize memory) to factory defaults.
      Solution
      To reset memory to factory defaults perform the following:
      1. Enter the 25 mode (power the machine ON, while pressing the 2 and 5 keys).
      2. Select Software SW.
      3. Using the up/down arrows, scroll to address 3-4 (All Memory Reset).
      4. Select OFF.
      5. Power the machine OFF.
      6. Enter the 47 mode (turn the machine ON, while pressing the 4 and 7 keys).
      7. Enter 0, 9, 3, and press the START key.
      8. Power the machine OFF/ON.
