Help for remove fuser unit Bizhub c451
  • babajaga
    • Jul 2025
    I need help(step by step) to remove fuser unit. My machine is Bizhub c451.
    Thanks!!!!!!
  • mo0651
    • 1054
    Step #1: Step away from the copier.
    Step#2: Call a qualified technician.
    Because you evidently can't see the 2 screws holding it in place.
    • babajaga
      thanks.
      • babajaga
        I successfuly reset fuser unit with new 80 ma fuse and all image drum with new chip.(black, yellow, magenta and cyan).
        Now I need help how to remove transfer belt unit. I have 80 ma glass fuse, but i can not take down transfer belt unit. Sorry for my bad english.
        • minimerlin
          • 851
          You are getting into dangerous areas now, it is easy to damage both machine and transfer belt assembly if you are not careful. I would also not advise resetting the transfer belt as you will get copy quality issues. I think it is time to either 1. Get a manual. or 2. call a tech who is trained on the machine.
          Please do not PM me without asking first.
