C352 "S1" displaying triangle
  • Haroldbfix
    • 212
    Clean all print heads, clean optics and Re ran Stabilization and Gradation. Replaced CCD per SSD recommendations same issue. All new IU's
    All ideas are welcomed.
  • copytechman
    • Nov 2008
    • 926
    Additional info if needed:
    S-1: CCD clamp/gain adjustment failure
    Relevant electrical parts
    Scanner assy CCD sensor unit
    Image processing board (IPB)
    1 Correct the harness connection between CCDB and IPB if faulty.
    2 Check for possible extraneous light and correct as necessary.
    3 Clean the lens, mirrors, CCD surface, and shading sheet if dirty
    4 Correct reflective mirror of the scanner if faulty, or change scanner.
    5 Change CCD sensor unit.
    6 Change IPB.
    Basically points to scanner section, not a lot to do with iu's or printheads.
    Regards!
    A.
    • graphshooter
      • Dec 2008
      • 5
      Hi, try to replace the lamp p/n:9351 3300 11
      • Haroldbfix
        • 212
        I ended up replacing the Lamp and the IPB. Did a trouble reset and re ran all gradation. So far so good. Thanks for the help.
