I have a customer who previously had a C450 mfp scanning to email through their company proxy server, and has been working fine. Recently, scanned pages are no longer being attached to the email, rather being embedded into the body of the email in code. We have swapped all boards, HDD and upgraded the firmware ROM with no success in correcting the issue.
As a short term workaround, and essentially a test, we have deployed a new C550 in it's place and are experiencing the same results. We have brought out a small tabletop AIO and configured it the same as the bizhubs, and this machine sends the emails appropriately, with proper attachment.
Here is the BODY of the received email (maybe there is something here that can help identify the problem) I have omitted the majority of the embedded code to keep this post from being to big.
To:chris.martens@oce.com
Subject:Message from 45C-1
Sender:fpcopier@francotyp.ca
Reply-To:fpcopier@francotyp.ca
X-Mailer:Generic 45C-1
Date:Thu, 19 Nov 2009 15:11:33 -0500
Message-Id:<4B056025.005.00206B5B0108.fpcopier@francotyp.c a>
MIME-Version:1.0
Content-Type:multipart/mixed; boundary="GENERIC_Internet_Fax_Boundary"
Content-Transfer-Encoding:7bit
--GENERIC_Internet_Fax_Boundary
Content-Type: application/pdf; name="test.pdf"
Content-Disposition: attachment; filename="test.pdf"
Content-Transfer-Encoding: BASE64
JVBERi0xLjQKMSAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdW J0eXBlIC9JbWFnZQovTmFt
ZSAvSkkxYQovV2lkdGggMTcwMAovSGVpZ2h0IDIyMDAKL0JpdH NQZXJDb21wb25lbnQgOAov
Q29sb3JTcGFjZSAvRGV2aWNlUkdCCi9GaWx0ZXIgL0RDVERlY2 9kZQovTGVuZ3RoIDIgMCBS
Cj4+CnN0cmVhbQ0K/9j/4AAQSkZJRgABAQAAyADIAAD//gALNDVDLTEgUTc2/9sAQwAFBQYH
BgYIBwcHCQkICgwUDQwLCwwZEhMPFB0aHx4dGhwcICQuJyAiLC McHCg3KSwwMTQ0NB8nOT04
MjwuMzQy/9sAQwEFBgYJCAkNCwsNExANEBMbFxQUFxsiHhsXGx4iKiYiHh4 iJiotKSYiJikt
Mi0pKS0yMjItMjIyMjIyMjIyMjIy/8AAEQgImAakAwEiAAIRAQMRAf/EAB8AAAEFAQEBAQEB
AAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNR
NjU1MzUgZiAKMDAwMDAwMDAwOSAwMDAwMCBuIAowMDAwNDM3Nj I4IDAwMDAwIG4gCjAwMDA0
Mzc2NTAgMDAwMDAgbiAKMDAwMDQzNzc0MyAwMDAwMCBuIAowMD AwNDM3NzYxIDAwMDAwIG4g
CjAwMDA0Mzc5NjAgMDAwMDAgbiAKMDAwMDQzODAxOCAwMDAwMC BuIAowMDAwNDM4MDkzIDAw
MDAwIG4gCnRyYWlsZXIKPDwvU2l6ZSA5Ci9JbmZvIDggMCBSCi 9Sb290IDcgMCBSCj4+CnN0
YXJ0eHJlZgo0MzgxOTYKJSVFT0Y=
--GENERIC_Internet_Fax_Boundary--
The proxy server being used is Proxy+ 3.00 Build 232
Attempts to configure email scanning directly to the ISP SMTP server have failed, as it seems all connections in and out of the network must go through this proxy server. It is looking like there is an incompatibility between the KM bizhub and the proxy server, which does not make any sense as this did work in the past. Any thoughts?
MIME-Version:1.0
