I have a big problem with this copier, when i want to make copies the scanner begins to tremble, then an abort message appears on the display and the copier starts to initialize again. What Can I do to solve it .
minolta dialta 351 scanner trembles
First thing to check would be if the foil, which is sticked along the exposure lamp, doesn't have cracks. If so they can be easily repaired with conductive paint. Some guys even soldered the cracks together which I never did. For me the paint worked fine.
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
the lamp has a short and should be changedThe greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
Please do not PM me without asking first.Comment
the problem was the exposure lamp. the foil was broken. thanks everybody for your answers.Comment
