Di3510 Doc Feeder Problem
  • OBXtech
    \tek-ˈni-shən\
    • Sep 2009
    • 37
    I've got a Di3510 that has a perplexing problem. The ADF will feed originals (single or multiple) just fine, but after the last one feeds through the copier sits for a handful of seconds and then displays a jam. Even though it scans the multiple originals, there are no outputs. The machine will copy fine from the platen glass.
    "I have not failed. I've just found 10,000 ways that won't work."
    -Thomas Alva Edison
  • Hansoon
    • Sep 2007
    • 3391
    Original empty sensor dirty?
    Hansoon
    • minimerlin
      • 851
      What is the jam area indication? Sounds like a sensor problem to me.
      Please do not PM me without asking first.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        I have had this happen 3 times. Change the pwb "A",on the copier, and it will be fixed.
        • krm
          • Aug 2009
          • 233
          Their is a clutch spring in the rear drive area that snaps off. It gives these identical symptoms. It loses a little interlock piece of steel, sometimes you can see it on the frame. first time, 1-2 hrs.
          • Imsdal
            • Aug 2009
            • 111
            ADF.
            I use to have a problem like that and its was cause of the paper, when the customer use punch paper the sensor light trought the punch hole and show that is jam.
            Try to turn the paper and see if any solution
            Sincerely
            David
            • digicor
              • 1159
              have you done any maint on the doc feeder recently? the little white arms that hand down have to be in the right position, i had this problem and it was this, they have to point backwords and ride on the frame as you open the doc feedr
              • FCBM
                Look on the shaft were the grey doc feed entrance tires are. Outside of each tire there is a groove. There is a small white plastic arm about 1 inch long that snaps in on both sides. If either side is missing or put back on backwards the shaft will rub on the entrance sensor. The first pages will feed thru no problem but the last page will always jam because it thinks there is still paper in the feeder.
                • digicor
                  • 1159
                  yeah thatswhat i was talking about
                  the litle white arms are usually the culprit....
