BH500 C-D282 error
  • aidil rashidi
    • Jun 2008
    • 33
    BH500 C-D282 error
    Hi again,
    I got 2 machine that suddenly gave out this error C-D282.
    According to the service book, either one of the OACB(Main contrl board),PRCB (print control board) or the SDB(scanner drive board). After testing I found that the error comes from the PRCB.
    I change a new PRCB and flash the latest FW in it. It works fine for a few days and it happens again. I change a new PRCB again afterward.
    My question is what cause the PRCB to spoil?Please anybody help me on this as I can't afford to chnage a new PRCB twice a month.
    P/S: I have check with my customer,there was no power blackout at their office when the problem happens. And the machine does not share a power outlet with
  • DadO
    • Dec 2007
    • 401
    DCPS (DC POWER SUPLLY) is giving power to the OACB so i would think that DC is your problem ( don't have to be a case, it could be an PCRB).
    I had the same problem except different code i relation to boards u mentioned. My machine sited in dark for more then 2 months till i didn't repair the OACB(it was to dam expensive so i understand u perfectly). I never saw nothing more sensitive than this piece of electronic cr*p.
    Try to check and clean everything what's touching the OACB even grounding!
    • ebaad27
      Re: BH500 C-D282 error
      bizhub 500 not suppling toner to and the bottle is not spining
      i clean the drum its blade etc also i clean the sensor present in the unit that comes after the toner bottle
      still problem exist any one who can help
