BH 600/750 drum blade loud noise.
  • SKTeK315
    Walter
    • Jun 2009
    • 142
    Hey everybody. Making loud squeeking noise from drum unit area. Any ideas ?
  • mabawser
    Tech
    • Sep 2009
    • 121
    has the blade flipped?
    Have you lubricated the drum with toner/powder before putting it back in?
    • DDProf
      Original dram and blade?
      • SKTeK315
        Walter
        • Jun 2009
        • 142
        BH600/750 drum area whistle loud
        Thanks for response. Yeas. Lubed.
        With orig. drum & blade & without.
        No it has never flipped. Yet. I have this with 2 Mach. On 1 I moved blade to middle of blade retreat lever till it stopped whistling. I was doing it with doors open during copying. Someone told me it must be in drub drive.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          Try a different blade, some just do not work. I have had bad luck with aftermarket blades from Viet Nam.
          • SKTeK315
            Walter
            • Jun 2009
            • 142
            BH 600/750 loud whistle from drum area
            A friend from minolta says most likely is somewhere in drum drive.
